If you're really after an aggressive and predictable track feel you'll need to look for springs with a linear spring rate. ST's are the only ones I know of that are available at the moment; Everything else is progressive. I'm not a Tokico fan but they're the only TEMS compatible damper out there. If you don't mind manual adjustment (preferable as you can tune each to compensate for any bias) then I'd recommend Koni.
If everything on the car is stock right now then anything you buy will feel amazing.
Also even just replacing all of the suspension bushings will probably make a huge difference for you.
