Through all gears you should still get a good pull as the turbos spool and as you move through your power band. As with any set up, as you move up through the gears it may be a little less. But from second to third as far as how hard it pulls shouldnt be that big of a difference that you would be concerned about. What kind of noise are you hearing and where does it sound like its coming from?
