I haven't gone outside and removed my lamps in a while, but I'm pretty sure they are all regular clear bulbs. So you should be able to use the same for LED's.
If you get LED bulbs, make sure they have a resistor built in (or you wire one in). Otherwise your turn signals will flash rapidly, and I'm pretty sure the brake lamp failure light on the dash will always be on once you hit the brakes.
