Thanks for the info. Supra is off the road at the moment while i get this wheel bearing sorted. I'll do a test run as soon as its done.
How much PSI does a stock 94' run? I have no idea if the previous owner of my car changed it at all, but when i go flat out my boost gauge shows about 12 i think.. If i did run higher psi, what's the highest that you'd want to go?
