A/c compressor won't kick in after work perfectly
First off my a/c coil burnt up so I replaced it. Then after that it still would not work. so then I found that the 10amp on pass side blow change it. Then the a/c was working great for 3 days. Till the 10amp blow again so I put a 15 amp in it and nothing a/c don't work. Also the system is full.
I checked already The CB, the relay under the fuse box out in bay, 15 amp cig, dual pressure switch. The only thing i didnt check was the amplifier but I don't know where it is or what is looks like.
