Have you checked for diagnostic codes? See the MKIII FAQ section for details.
Check that the grounds for the EFI system are CLEAN and well connected. There are a couple grounds bolted to the passenger side of the head toward the back (cyl #6) and a couple more on the driver's side which are bolted to a stud beneath the upper intake plenum (between cyls 5 and 6).
