Originally Posted by cre
Well, the KVAFM is an optical metering system. While it's sealed to prevent damage some moisture seeping in can fog the optics and render the sensor useless... It would take a lot to soak it to the point that the temp sensor would degrade beyond providing any signal though.
So did you actually try your friend's AFM in your car?
Well I tested the green and red wire and it was bad (the one that the safc2)
