You can override some of the fuel pump circuit by placing a jumper wire in the diagnostic box between FP and B+. This should cause the fuel pump to continuously run when the key is in the "on" position.
If you can't hear the fuel rushing through the fuel rail, you can take the fuel filler cap off and listen for the pump through the filler neck
