Originally Posted by turbonicsperformance
yes the sensor itself is the same between the 7m and the 1uz but you dont want to use the housing unless you have injectors to match.
Thank you If I were to use the housing what injectors would I need and would anything else need to be changed? What is the outcome more HP?
