Originally Posted by pwpanas
You need to pressurize your intake system with an air compressor (up to 15psi should be fine) ... all the way from the air filter/maf back...and listen for leaks. You'll have to rig up an adapter from your intake/maf to the air compressor.
It turned out to be fuel cut!
