Old 09-30-2011, 01:17 AM   #11
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by todd5854 View Post
Since it's obviously unibody, it's hard to answer that question. But if you consider the spare tire housing/floor support to be the frame, yes, that's bent. But inside the quarter panels, on the sides, it's not bent.
Do a compression test on the engine. If it reads 165+ in all six cylinders, and you can limp it for a test drive and it shifts smoothly, then worst case you can part it out and make your money back.
Life begins at 30psi.
