Originally Posted by todd5854
Since it's obviously unibody, it's hard to answer that question. But if you consider the spare tire housing/floor support to be the frame, yes, that's bent. But inside the quarter panels, on the sides, it's not bent.
Do a compression test on the engine. If it reads 165+ in all six cylinders, and you can limp it for a test drive and it shifts smoothly, then worst case you can part it out and make your money back.
