Originally Posted by midwestmk2
Ill have to say yes to Alpine but only for head units.. If it comes to subs id have to go with LANZAR.. I had 4 10"LANZAR heritage series 800watt subs running off a Rockford 500a.2 bridged mono..It was all in a 86 cuttlas with a set of 1000watt 6x9's and 500watt 3" peizo tweeters in the dash..They hit so hard that the speedo would jump up at stop lights and could blurr my vision on the highway with the windows down.. :blink: The whole setup only cost me $800 with every thing including the wireing..Nothing like having truckers looking over at you on the highway or over blasting someone who thinks theres is loud..Setting off car alarms for 50 yards,Beautifull.. B)
Hey id have to agree lanzar heritage serise is a great set. I got 2 12" 124D's in a Band Pass 4 port box. Now with a Vibe 248 amp pushing 500RMS per channel its good only thing amps getting kinda really hot so at these settings it sounds n hits fine just the heat issue:
HU Settings:
Bass +12
Trebel +12
Sub Lvl +4db (max +/-6db)
Sq Set 60hz+6 (can be +12 or 0)
LPF Hz 80
HPF Hz 180
Amp Settings:
Amp level is about 85%- 90 up.
LPF about 25% like that on the amp gain to the left so you can turn it up more but its pretty low.
HPF about 70% to the right of the adjust(gain) knob.
Freq Amp set: Low
Thoes are my settings
These are the settings so ya maybe any one have any reccomendations and stuff id love for some help at fine tuning my system. My hole system is.
Panasonic 50x4 watt deck
2 Infinity 6002i's
2 lanzar 12" 124Ds 1000RMS
1 Vibe 248 amp 500rms at 2ohms / chan.
THANKS!
