Old 10-04-2011, 07:35 PM   #10
87hilux7mge
87hilux7mge's Avatar
now ranma, there are cheap ppl here, but most of us are "budget minded" (ie: basically cheap haha)
i dont mind spending some bux to make my car/truck better. but when it comes to 80 dollar bearings that have gone out within 5-8k miles, that adds up, and it shouldnt be that way.
ive had to replace my dads carrier bearing 8 times since hes owned the truck. that is the only thing besides brakes, air filter, plugs, wires and oil changes hes had done. we finally put a one piece driveshaft in, and voila, works perfect with no problems, for the past 35k.
a one piece drive shaft takes less power to turn, therefore providing more power to the ground. so if you do a performance build it is advantageous.
in the case of carl's (thread starter) he wants a drive shaft that is easier to change u joints in, and one that he doesnt have to replace the carrier bearing so often in. he pushes this car pretty hard. so a one piece driveshaft enables him to have longer running intervals before replacement of u joints, as well as more power to the ground, while sacrificing minimal ride comfort.
for his application, it works and is reasonable. for a daily street driven supra, the stock 2 piece driveshaft is definitely more comfortable and suits it just fine.
