If checking signal from the coil by testing the two wires output... yes. I dont know what the reading should be however. If testing it by means of putting a screwdriver in my mouth and turning the key... well I have done that too lol. I have tried 3 known working coils, 3 working igniters, 2 working CPS/distributors, 2 working ECM/ECU and even two different batteries. I have jumper cables from the neg terminal to two different points on the chassis and the motor so it is not a ground.
Only thing I have not tried is testing the ignition switch itself???
I dont have the manual, but ordered one as we are all aware they are not readily available anywhere.
