Originally Posted by cre
Still, I'd go through the usual steps of testing for boost leaks (with an actual tester you'd be surprised how easy leaks are to miss), check timing and check for error codes.
Leaks from where? Like all my vacuum lines and stuff u mean?
1988 7M-GTE Manual Turbo, Godspeed IC, Stock HG Torque to 90FP W/ Arp bolts, Silicon water hose kit, silicon vacuum hoses, Godspeed radiator, 2 12" electric fans.
