Stumble/Miss at 1500 rpm
I rebuilt the 7MGE in my 1989 Supra. .030 oversize pistons, new bearings, head rebuilt, new everything, MLS head gasket, ARP studs. Runs great, idles perfectly. However I get a stumble at 1500 or so RPM. Happens when I slowly rev in neutral or when I accelerate. Bad enough that the check engine light will flicker sometimes, but will not remain on, Will happen in all gears if I shift early enough to get the rpms to drop below 2k. If I punch it during an acceleration stumble, it will miss and stumble worse. It is driveable, but very annoying. Fuel pressure is fine. New distributor cap, rotor wires and plugs.
Did not do this prior to being rebuilt, not sure what has changed.
