Old 10-18-2011, 05:20 AM   #1
spainobain1234
spainobain1234's Avatar
spainobain1234 is on a distinguished road
Exclamation ISsues with the Supras
Common issue. NEED answer. I have a 1987 7mgte auto blue interior blue exterior, 150,000 miles performance short block and overhauled turbo ct26 not sure what overhauled means, but the receipt tells me so?
First of all, where can I get replacement rubber that surrounds all the glass on the hatch, the windshield, and the rear side windows?? The black rubber is peeling off of the chrome around the glass, is this weatherstripping? The chrome around the windows is ugly, and I need a solution to making the chrome around the windows black again. Thank you!
Second of all,
please help me, My fog light switch does not turn on. I flip the switch and there is no click sound that tells it is activating. Also, the switch does not light up when I turn the fog light switch to "on" position. Please help me figure out if this means that i only need to replace the switch. The bulbs in the fog lights themselves are brand new. Thank you!
Third,
how much will it cost for a decent paint job. Mine is blue, SHOULD I paint over the side trim molding, remove the side trim molding? How can I get the side molding trim chrome finished.???
Fourth,
Overhauled turbos. How long will it last at 6 psi if I floor it all the time?? How can I tell if it is a 57mm of 60mm CT26??? PErformance short block as well? Is it unhealthy that I have a 3 " downpipe, elbow, and then straight pipe 2.5 inch all the way back with flowmaster crooked muffler at the end? (looks pretty cool actually)? Will this burn my valves, because someone told me that straight piping will burn up my internals... ? ? That made me nervous.
Fifth,
I want to paint my supra, FLAT ARMY GREEN with deep dish rims.
Thanks ahead of time and I appreciate the responses. This is my first mk3 MA70 model supra. I name it Rupert the 3rd
ID:	4285   Click image for larger version
ID:	4286   Click image for larger version
ID:	4287   Click image for larger version
ID:	4288   Click image for larger version
spainobain1234 is offline   Reply With Quote
