Old 10-18-2011, 11:53 PM   #34
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
wat flywheel is better aluminum or act street lite steel flywheel need to buy new one
I assume you mean "what" when you said "wat". Please let me know if this assumption was not accurate. If you meant something else, this response may not make any sense (I've never heard of a "wat flywheel" - maybe that's a new brand? If so, please provide a link):
The decision depends what you're going to use it for. If you're going to be drag racing with high horsepower, a heavier steel flywheel makes a turbo car much easier to launch. If you're going to roadrace with a good traction control system (eg. RaceLogic), then as I already said above a very lightweight aluminum flywheel will let your driveline rev up much more quickly. For daily-driving street use, the oem dual-mass flywheel can't be beat...it's heavy which makes for foolproof smooth launches, and the dual-mass dampening keeps everything as quiet as possible.
Life begins at 30psi.
