Originally Posted by warmkop
I meant what sorry.I decided to build the supra for the dragstrip.
Took the clutch out last week but the flywheel has to much play/wear need to replace it.
Wil the stock ignition system be okay with the aftermarket managment.
The oem TT ignition is fine if your aftermarket engine management system has at least six ignition outputs. Iridium spark plugs are recommended.
Note that (for example) the
AEM gen-1 has only four ignition outputs, which puts the 2jz-gte into "waste spark" mode...and in "waste spark" an
ignition amplifier like the "
HKS DLI-2 Twin Power Ignition Amplifier",
or an "
AEM CDI Ignition System" is required.
