No heat help
I am baffled the bpv valve seems to be working but no heat engine running fine at normal temp. new thermostat, radiator cap., is there a fuse for the heater somewhere, no leaks in heater core either. any help would be great..., now the car seems to run a little on the hot side. where should the need on temp gauge be for normal operation?
Reason: new problem
