use a ratchet and socket and remove the 2 10mm nuts off the oil drain on the block... you should have access with the tools from the engine bay top side
so basically have the ratchet horizontal to the oil drain nuts and you should be able to remove it
Pics of my build.
Do a diagnostic first!
