No heat from heater
I tested the valve and it doesn't work bypassed from top of solinoid vacuum line to vacuum line from where the switch is and the lever is pulling up now, but still no heat. Truly stumped. removed thermostat and drilled giggle valve out to a 4mm hole. new Radiator cap, and still no heat
