Don't expect a consistent idle with the TPS unplugged... the TPS is used to control the idle afterall.
1500RPM sounds like a fuel cut issue, could be due to a number of factors.
You say you cleared codes... what codes? When did this problem start? Have you done any work on the car prior to this problem starting? If so, what?
