Old 10-22-2011, 07:12 PM   #2
Originally Posted by icey756 View Post
But is it possible to just wire them to the wires that ran to the stock electric fan?
No. And the A/C temp switch which some recommend comes on at a higher temp than is generally desired... You'll need a thermostatic switch for the right operating temp and a dedicated wiring harness (don't forget the fuses and relays!).
And I'm assuming that removing the mechanical fan is ok and i just have to get some nuts and bolts that will keep the pulley on.
Yes. If the hit the spot on the studs where there are no more threads you may swap out the studs for some bolts about 1/2" long... I'd use hardened bolts for a little more piece of mind.
Do note that that is for a JZA70 chassis/engine setup and not a MA70. It's not a big deal but schedule some extra time in there for correcting any fitment issues and go buy a plug for the opening by the drain before you start. As they ditched the fan cowl and the A/C fans you obviously don't have to worry about fitting those but the rubber feet will need to be shortened a bit over 1/8".... I can't recall if there's anything else.
