10-29-2011, 12:08 AM
#2
Supra Owner
Originally Posted by kingofva87
 Im trying to get in the Supra game, I currently have my eye on a 95 Singled T-70 with fairly light modifications. He currently has a full Apexi N1 exhaust its a straight shot from the down pipe ( no cat/ no mid pipe ). The car is also running an AEM Stand Alone V2, now my question...the car is OBD1 I will need to pass emission's in virginia  , I need some advice on whether I would be able to slap a high flo cat on and possibly tune the vehicle as close to the stock settings as I can in order to pass the Sniff test. Currently the car is running a bit rich, I just need some advice on this virginia is brutal with the emissions and im not trying to be stuck with this Supra and not have a shot in hell at registering it.
1) Was it a TT?
2) Yes, it should pass tailpipe 'sniffer' emissions with a high flow cat and a well-tuned AEM. Have your tuner lean the H-E-double-hockey-sticks out of it.
3) Why did you create two separate threads with exactly the same post in each?
Life begins at 30psi.
