my gauges r screwed!!
Hey wats up i have had aftermarket gauge cluster pretty much ever since i have had the car ( about a year) and a little while back all my gauges went crazy! They are all screwed up the speedo dont work, the gas gauge will only go to half a tank, the boost gauge is on -6 till i redline then it shoots up to 6, temp always on hot, oil pressure is messed up, but the tach works perfect anyways my ques is me and a friend took the cluster out and checked it out the wiring looks fine we think the needles went bad if so can i replace the needles or do i have to get a new cluster and how would i know for sure if it is the needles????
1987 5-speed Turbo, JDM 7M-GTE, K&N air filter, 3' straight exhaust, Blitz BOV, Upgraded CT26 Turbo, 3' Down Pipe, NGK Iridium Spark Plugs And Wires, Megan Racing Strut Bar
