well just a little update. it was the same rod again but this time it completely spun the bearing and screwed the crank pretty bad the rod doesnt look too good either. I'm gonna call around and see how much some machine shops want to grind polish and campher the crank and true the rods and see what comes from it, otherwise it might be bye bye 7m hello 2j or 1uz. I love the 7m I love the 28 mpg in town and i LOOOOVVVE the torque and sound of it. I also love the unique-ness of the swap and that alot of people dont recognize the engine. it'll hurt to say godbye but if its gonna run me more than $500 for the machining bearings and oil pump then its just not cost effective to stay 7m /: i can pick up a 1uz or 2j for 500 with trans and ecm right away.
92 miata 7mgte swap  forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
