Originally Posted by turbonicsperformance
the block is fine. if it were the block it would have been all the rods or atleast a different rod than before. i'm gonna try and be able to rebuild again but if not the the cost of a jdm 7m is getting WAYYYY up there whereas a 2jz rb25 or 1uz is still reasonable. hell a jdm rb25 with trans ecm turbos wiring everything is only $1300 and can make almost 400 on stock turbos. so its just not smart to stay 7m if i need a new block assembly or if the cost goes over $500 because there is a 2jzvvt and several 1uz at the local junk yard for 335 with trans and ecm/wiring
Dude there is a time for everything, so tell me why you are having such problems. Me my time is worth a lot to me! Then you have the parts, etc. You would be better off recycling the short block and replacing it. Then again have you considered your driving?
