Originally Posted by turbonicsperformance
the block is perfectly straight i checked it before it went together and just today when the crank was removed . it was rod #2 again im pretty sure that rod was out of round or something. its gonna run me 185 to have the crank and rods all redone. the block is gonna be flushed using brake clean at 120psi if theres anything in the block itll come out of it. YES my driving is very hard the car had 1200 miles on these bearings and maybe 300 of them are normal driving the rest is spirited driving around town, highway pulls, the strip,and drifting but even if the engine were driven at redline the entire 1200 miles the bearings should be able to handle it. the pump IS a 7mge pump and my cooler relief spring has a crack in it. i've found several things contributing to this problem. last time i just thought i was unlucky and got a bad bearing so i dropped the pan and put some bearings in it. this time i dropped the engine and put it on the stand so i'm finding the things to can't see until they come apart /: Oh well if it throws another rod then this block will go to the scrap bin I have the 185 plus parts now but i dont have the 335 plus for another swap at the moment.
My suggestion for you is not to drift or race your daily. These cars were not designed to handle the stresses from these "activities". You should use your Supra as your daily and something more appropriate for your drifter, like a Fire Chicken. My old Fire Chicken with its 5.7 litter engine was a blast. A lot more torque than my Supra and the drive train that would not stop! The rest of the car was garbage but he could run! However now that I have "reformed", the Supra works fine for me
