its not a supra i drive a miata with a 7m in it . i built it to handle the abuse ie coilovers swaybars, beefed diff, better clutch, tires and rims all that good stuff. but most of the time it is street driving. I get what your saying though you need a dd and a toy. but everything on my car has held up perfect besides the engine. this time it should be good though new oilpump crank and rods machined for the bearings rebuild the head and new cooler setup. we'll see
92 miata 7mgte swap  forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
