glad you found the problem! hopefully you can get it back together quick and up/running again. if you need another crank, ive got two 6m's that are good, one i just had polished the other day (it has been heat treated on the main and rods). the second is bone stock and needs a polish.
good luck with it, and if you need parts, lemme know
