That link won't open for me. Whatever washers you use make sure the rubber is either a butyl or silicone with a HIGH shore rating and absolutely NOT Neoprene; The material used for Neoprene backed washers generally has a low shore strength and is not very tolerant of engine heat resulting in quick breakdown and compression and thus loose bolts... you're better off with just copper washers over these.
