Don't over torque the bolts (22INCH lbs, NOT 22ft lbs) and if needed apply a little medium loctite.
EDIT: Additionally, I don't recommend allen screws. Don't use anything for which you'll need a new tool in your in-car toolkit to service. Get some bolts with an 8mm or 10mm hex head... a flange bolt with a fiber washer would be even better.
