Thread: 7m head gasket
Old 11-21-2011, 04:54 PM   #10
Ranma
Ranma's Avatar
Talking
Originally Posted by Awyman18 View Post
get ur head checked, make sure nothings warped, and have them clean it like i did. machine the head, if u want take the block in and do the same thing. straight edge the block, if u dont know wat that is, take it to the shop. I ended up just using sand paper on the end of a drill and buffed the block clean, but i caught my hg very early. and arp head studs u torque to 120lb, and arp head bolts are 78lbs...so studs are alot stronger with the torque and design
Need to take it in for a pressure check. A small crack will drive you nutty!
Anyhow there is no such thing as a over build for people in this forum! The kids (no set age) are hard with their toys! This includes me! so the better it is put tougher means the less chance it will break soon.
