Originally Posted by [SupraLEGEND]
Thanks for replying. I hear you. I read on a technical section of a different Supra forum that the W58 can safely handle (I stand corrected with this figure) around 300rwkw (roughly 410HP) which is more than what the stock 2JZ-GTE puts out. By that they mean that you can open up the boost even more on a GTE and not worry about the tranny breaking if you're running it thru a W58. What do you think?
A completely stock 2jz-gte means stock turbos...and 410rwhp is right at what most BPU 2jz-gte's do (6spd). The record for a new 2jz-gte with new oem twins, bpu'd, is about 4
75rwhp. Personally, I'd never run a tranny that was right on the edge of breaking, but I guess that's your choice. I wish you all the luck in the world, because you'll probably need it. If you don't want to depend on luck, get the transmission that was designed to go with the 2jz-gte - the V160.
