11-27-2011, 05:30 PM
#10
Supra Owner
Originally Posted by Johnny A
...The only thing wrong I could find was the valve stem oil seals are leaking oil when the engine is cold so you get blue smoke on startup, I have heard this is a fairly common problem with these engines. Would new seals from Toyota cure the issue??
Yes. Here's the tech article:
http://bellsouthpwp2.net/p/w/pwpanas...ra%20Turbo.htm
Life begins at 30psi.
