Originally Posted by [SupraLEGEND]
Your name is Phil right?...
Yes.
...I took a look at your Supra on your MySpace page. She's hot man, hot!...
Thank you!
...Wow, are Ohlins really THAT good???...
Absolutely, but I'll let you decide. For starters, take a look at the price:
http://www.ohlinsusa.com/us/index.ph...road-and-track
...My needs are completely taken care of by both Supras - you reckon the Ohlins are overkill right now and I agree however, doesn't that also mean that I score big in that department if I do in fact buy that Supra with Ohlins - when I eventually do become hardcore amateur, semi-pro, the car already has such suspension?? Right, I've asked the dealer more questions about brakes, transmission and so on and will report back when he tells me more. Aww yeah, the '93 has HKS suspension which has been very successfully road-raced - I love the sound of that  ...
Agree. I'm not saying it's bad to have too much suspension (except perhaps in the area of maintenace costs). However, I am saying the upgrades on that car are a bit unbalanced...too much suspension and not enough brakes. It's just an overall comment about the choices made for the specific combination of modifications. Like perhaps a project abandoned partway through? From the perspective of a project car or a starting point it's just fine. From the perspective of someone that wants to take the car out and seriously roadrace day 1, perhaps it's not optimal. *shrug*
...About the racing pads. I answered you based on what came to my mind when I heard about them - perhaps they are TRD and if they are, I read on TRD's website that their pads offer "higher initial bite" than standard. They weren't referring to the Supra I'm sure because the Supra, as you say has very good brakes and pads as is but, what I gather from them is that's what they term "racing pads". If you buy TRD pads specifically for the Supra then, I'm guessing the performance will be even better to say the least. Just me putting 2 and 2 together because of a lack of information as to what the car actually has...yeah, if he didn't do the rotors as well, it's a pity...
The oem rotors are in fact better than aftermarket slotted and/or cross-drilled for pure braking power. However, there's no way to upgrade the rotor
diameter without also changing the calipers. That's the level of brake upgrade that should have been done to match that suspension, imho.
...What do you understand by a racing blow off valve?? they didn't give me a brand but said that the '93 RZ has a racing blow off valve - it doesn't look like an HKS or Blitz in terms of size but, it's definitely a BOV. How do you think it will perform (sound as well)? It's mounted where the original BOV is/was if that helps......
There are a very few areas where the Toyota let us down with the oem components, but the oem BOV is one of them. Inside it is just cheap plastic, and with the heat generated in the 2jz-gte engine bay the oem bov has a limited life span before it starts leaking. Pretty much any/every BOV will perform better than stock, especially in the reliability area. Of course, if you upgrade to a large single turbo, you'll also need larger size of BOV(s) to vent a greater volume of air during a blow-off.
If you're running the oem MAF, be sure to get a BOV that has an output routed back to the post-maf intake tube (as it is in the oem configuration). If you vent the BOV to atmosphere (again, with a MAF), you'll run overly-rich every time the BOV vents, which can stall the car and/or foul the plugs and/or wash down the cylinder walls.
...I can't wait for this car man...years I've longed for it and now, it's finally in my midst - I can't describe that feeling to you in words...
I do wish you the best of luck in obtaining a Supra. Please keep us informed on your journey!
