Originally Posted by Turboron_99
Dont forget Steel will be alot more Prown to Heat Soak than nice Aluminum! Plus putting a rolled in Beed on Steel would be a PITA! Would probably have to weld a beed to the pipe!
Actually aluminum transfers more heat from the engine bay into the charge-air system. Get the pipes ceramic coated to reduce this issue.
There is a machine that easily presses a bead into steel pipe. Many of the shops that have mandrel bending equipment also have the bead making machine.
