Old 12-03-2011, 04:49 AM   #10
Codyjamesuno
I've never heard of an HKS side-mount intercooler designed specifically for the Mkiv Supra Turbo. At one time, GReddy made an all-aluminum side mount kit, and it came with all of the piping.
Regardless, if you replace the oem rubber-like and plastic intercooler piping with (preferrably) aluminum piping that follows the same path, you won't need to re-tune at all. I'd recommend against steel piping because it's too heavy, and you don't need steel pipe to hold <40psi of air pressure. Be sure to use silicone couplings and t-bolt clamps.
opps, you were right, it is a GReddy intercooler, I am sorry my bad on that! You must know your stuff!
