But no new codes are stored? Then start with the usual suspects... Battery cables, alternator (unlikely), relays and grounds.
The only other thing to try is put the diagnostic jumper in and (with a passenger to count any flashes) go for a short drive.... Should only see a code 51. There are some codes which only appear while the fault is actually happening.
