Thread: Hello
Old 12-04-2011, 03:54 AM   #4
Turboron_99
Turboron_99's Avatar
Turboron_99 is on a distinguished road
Thanks for the Help Cre,
Maybe you can answer this also, The Supra i am installing these on is a '87 Turbo. The Hub bore of these wheels are 3.3 inchs or 83.82MM. I think from what it looks like is that the bore on the hub itself is like 60mmish. So i would need a 60.1mm inside to 83.82mm outside diameter Hub Centric ring?
This is the plan i came up with today,
F 16x7 0mm Offset wrapped with a 205/50/16
R 16x8 +12MM offset wrapped in a 225/50/16
I know that the Tires will more than likely poke past the fender, but what ever. These steelies have a lip of 3" all the way around and are 8 hole (Circle cut).
Turboron_99 is offline   Reply With Quote
