Old 12-06-2011, 11:41 PM   #1
mkiii<3
mkiii<3 is on a distinguished road
Default Valve Cover bolt replacement
Hey guys i had a question i recently replaced the no.3 gasket and did the whole oil drain plug thing discussed on another thread and when i was putting back the valve covers the phillip screw bolts that hold them down gaveme problems when trying to torque them down i ended up strippin the top on two of the screws.. my question is what kind of bolts should i replace ALL of them with and also if i should put washers or use the gold looking washers on the stock bolts on their right now.. thanks..** i read this post: http://www.toyota-supra.info/forums/...placement.html but their talkin about two different type of bolts, which one should i go with?
1986.5 mkiii manual 7mge n/a (soon2b7mgte)
mkiii<3 is offline   Reply With Quote
