Old 12-09-2011, 01:07 AM   #29
mechrider89
Originally Posted by 87hilux7mge View Post
well, just found a 91 talon tsi, 400 bux...guess i should eat my words. lol. need the motor gone through, but its a 6 bolt (skipped teeth, bent valves) and the rest of it is in great shape.
figure i can rebuild the motor for about 6-8 hundo and have a good lil car
The bottom end should be fine, just take a quick peek at the pistons and if they have light marks from the valves they're fine to run again (unless the rings are shot of course). Check the head out make sure its not cracked, if not may as well send it away for port& polish. If your lucky you'll just be looking at valves and a head rebuild, in most cases its just valves that need to be replaced. keep me updated man!
