Not likely. If the plug recepticles on the ECUs are different colors then they're not compatible (not entirely true for the 7M-GE ECUs, but there are a few reasons you still want to avoid mixing the two). It isn't a big deal, as I mentioned before the A/T ECU will be fine with a manual transmission and the ECT computer disconnected.
