Did you use the key in the door lock??? You must use it to re-set the security system. Yes, you say??? Then did you try the passenger side?? If it worked on passenger side, then the switch in the drivers door is worn out or busted. If it did not work with passenger side either, then you'll have to trouble shoot the system using the online TSRM.
THe passenger side seldom goes bad because it is hardly used.
