12-16-2011, 09:17 PM
#17
AEM EMS
Sounds familiar: 180 degrees, Link see the paragraph just below the 16th picture paging down.
CAUTION: The gear must be put back on the correct way. It has a 13 tooth wheel, so you can be 180 degrees off and really screw up. The TSRM describes how to align the gear properly. Basically you point the reluctor at G1, and then put on the gear so that the little hole lines up with the slot in the CPS housing. http://www.cygnusx1.net/Supra/Librar...ion=IG&Page=23
