Go Back   Toyota Supra Forums! Join the Supra forum! > Authorized Vendors > Arizona Performance
Old 07-26-2007, 04:54 AM   #1
ARZ
ARZ is on a distinguished road
Default 13 inch Wilwood MKIV/SC300 front brakes
This Kit fits both Lexus SC300/400 and MKIV
all photos are shown installed on a Lexus SC300.
THIS IS A BOLT ON KIT!!! All you need to complete the install is brake fluid and tools.
Our kit consists of:
2, 13 inch diameter x 1.38 inch thick directional curved vane Wilwood rotors
2, Rotor hats, specifically made to fit the MKIV hub (These will include all the grade 8 fasteners)
2, Wilwood 4 piston "Forged" Superlite Calipers
2, Caliper brackets and "press fit" threaded inserts installed
2, Brake lines "braided stainless steel" with all the required fasteners to install in the factory brake line retainers.
4, Brake pads, Wilwood Street Compound = low dust = excellent cold performance
And all the EXACT fasteners required to make this a bolt on kit.
You have never felt a Supra or Lexus stop like this. You wont be dissapointed in these brakes. If you have ever over heated the brakes in your car you know how scarry it can be. You will be blown away by how much better than STOCK these are.
Heres the install thread Wilwood front brake install thread
Now for the price $1295!!! plus shipping and handling.
Please Email arizonaperformance@cox.net or call 480 861 0586
Heres the difference between the Wilwood rotor (13.06 inches in diameter and 1.375 thick) and the Lexus SC300 (10.75 inches in diameter and 1.10 thick)
Heres the difference between the Lexus Caliper and the Wilwood, these things are a huge improvment over stock.
89 Turbo 5 Speed hard top
1971 240 Z, 7MGTE, 5 speed, 487 RWHP @ 23 PSI, weighing 2505 lbs.
www.ArizonaPerformance.com
ARZ is offline   Reply With Quote
Front brakes sticking fwsprague Non-Generation Specific Questions 4 05-22-2008 09:38 PM
Two Issues: Front Brakes and Sporadic Vibration Chambers MKIII Supra 0 11-03-2007 04:15 PM
Front Brakes zuni MKIII Supra 8 06-21-2007 05:09 PM
13 inch Wilwood MKIII front brakes ARZ Arizona Performance 0 03-16-2007 07:57 AM
