Go Back   Toyota Supra Forums! Join the Supra forum! > Supra Specific > Car Audio and Alarms
Old 02-23-2011, 11:40 PM   #11
jtown125
jtown125 is on a distinguished road
Most of that I answered by editing my last post. 15 v at power to amp.
0 ohms at ground. and 14 v at remote wire...amp setup is good. and yes the default settings for the sub were setup...i checked.
89 mkIII turbo supra stick black w/ maroon interior!!!
jtown125 is offline   Reply With Quote
Old 02-23-2011, 11:45 PM   #12
Originally Posted by jtown125 View Post
(sub will only hit when radio is on, NOT CD, AUX, and etc...)
Wait.... what? Are you saying the subs do work part of the time? If the remote/signal line is a gnd input try grounding it to the chassis and see if it functions continuously; And, if it's a positive signal then try connecting it to a full time positive signal.
Post the make and models of what you're running (dammit)...
EDIT: Oh, and the speaker going in and out is more likely bad wiring. If you're using the stock wires for the regular speakers there may be a break in the section which crosses from door to chassis.
You're not using any of the stock wiring for the amp and subs, are you?
Old 02-23-2011, 11:54 PM   #13
jtown125
None of the stock wiring touches the amp or sub wiring. The cd player had a harness kit put into it to plug up to stock harness (remote wire is ran into the kit between the cd player and stock harnesses)
And the sub doesn't hit at all, I have it set up to where it will only hit when the radio is turned on (when the antenna gets power, the antenna doesn't come up with the cd setting or any aux setting)
(make and model in sig)
Old 02-24-2011, 12:14 AM   #14
That's a joke right?
Make and model of the stereo and amp............?
Old 02-24-2011, 12:24 AM   #15
jtown125
lol
panasonic cq c9901u head unit
and a legacy predator 1000 watt amp
and a boss diablo 800 watt sub 10"
Old 02-26-2011, 09:07 PM   #16
Hey, been busy and haven't been able to look up anything on those components yet. Had any luck? If you've got a small radio with RCA inputs I suppose you could try running the sub wires to that to see if it's getting a signal. Have you tried new cables? Have you checked the gain and crossover settings on the amp? Have you checked any fuses in the amp?
Old 04-22-2011, 10:26 PM   #17
jtown125
hey cre (two months later lol...)
so i hooked the remote wire up to the ground wire coming from the stock harness...and it worked. depending on what system you had in the car depended on whether you had a positive or neg remote wire.
Old 04-24-2011, 06:51 PM   #18
Gee.... I thought I covered that... somewhere like post #12.... must have been imagining it.
Glad you got it figured out... 2 month long problems usually involve me pawning the problem off onto someone else while I just stand by and "supervise".
can you make these work with a 1jz swap..? JZA70dood Non-Generation Specific Questions 0 08-12-2009 04:17 PM
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
N20 and HeAd WoRk Supra_87_mk3 Non-Generation Specific Questions 4 05-25-2007 03:09 PM
Dash lights Don't Work supra67 Non-Generation Specific Questions 4 09-05-2006 04:58 AM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
