Go Back   Toyota Supra Forums! Join the Supra forum! > Supra Specific > Car Audio and Alarms
Old 05-14-2010, 05:37 AM   #1
batmmannn
batmmannn's Avatar
Default Alarm Defect stopping car from starting
Ok My Dad has an MK3 as well it has sat for years because the alarm does not work properly and the car will not turn over, something as I recall that you had to turn the door key a certain way to reset it. Any ideas on what this might be? I was surprised not to find a thread on this here already.
Thanks
Old 06-09-2010, 03:48 PM   #2
kadinz
kadinz is on a distinguished road
Thanks
well, mine doesn't work well but if/when my alarm does go off(rarely does, im too lazy to rip the shit out.) i turn the trunk key like every which way i can lol it works sometimes, other times i just open my hood and rip the battery terminal off. now to bypass the alarm cutoff you need to cut 1 wire under the steering wheel. i completely forgot which wire it is, i think it's yellow..don't quote me on that though. it's the ground for the starter.
it always seems the car car knows when it's raining or not very nice outside because thats always when the alarm goes off >_<
kadinz is offline   Reply With Quote
Old 07-14-2010, 03:14 PM   #3
aisloy15
aisloy15 is on a distinguished road
I like your discussion.Thank you very much.
mac dvd ripper
mac dvd to ipad
aisloy15 is offline   Reply With Quote
Old 07-18-2010, 06:04 PM   #4
cledamaeu
cledamaeu is on a distinguished road
Default Alarm Bypass
So seriously now, how do you resolve this Alarm Shut down? I wa going to sell my Supra 88' but can't do this until the %$#^%Alarm is bypassed.
cledamaeu is offline   Reply With Quote
Old 07-18-2010, 06:08 PM   #5
cledamaeu
Default Alarm shutdown on my Saint Supra!!
Thanks
If you get an answer let me know, I was going to sell to a loving MotorHead but if it won't start, there will be no test drives for that perfect home. I love my Supra but I am at a loss on this ShutDown alarm thing!!
Old 07-20-2010, 04:08 AM   #6
I'm posting this this one time only... I will be deleting this thread in the morning so read up and take notes. (and, of course, if your preferences are setup to email you when replies are posted you'll get all of this in your email)
FIRST! Look here:
http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=122
System delete:
1) REMOVE the Theft Deterrent Computer.
2) Now ground the blue wire with orange stripe (Pin 13).
3) Install good aftermarket alarm.
4) DONE.
System reset (the sure way). Do this AT the deterrent ECU's connector with the battery, theft deterrent ECU and all fuses installed correctly:
1) Jumper the violet with yellow stripe wire (pin 3) to ground.
2) Jumper the blue wire with red stripe (pin 10) to ground.
3) Disconnect both and start vehicle. If it does not start after this test for a ground signal at the starter relay's coil while the ignition is held at STA. If no ground is present either the wiring or deterrent ECU are damaged. If there is then the security system is not to blame.
Old 04-23-2011, 10:23 PM   #7
Fundamental
Fundamental is on a distinguished road
the same thing happened with my 88'. had to take it to a dealer and they said the alarm in the door shorted out. they disabled it then a few hours after i got it back the same thing happened. took it back to the dealer and it was the other door this time. havent had a problem with it since.
Fundamental is offline   Reply With Quote
alarm? starter? dunno help plz Scionguy MKIII Supra 3 11-04-2008 08:35 PM
Car alarm with a mind of its own suprascoot MKIII Supra 10 03-08-2008 11:09 PM
starting motor Dom MKIV Supra 3 04-05-2007 01:57 PM
1986.5 Starting Problem supraman121 MKIII Supra 4 09-03-2006 03:51 AM
engine noise car dies after starting tex1116 MKIII Supra 7 11-18-2005 06:47 PM
